93 stratos livewell timer module
AuTiger
I talked to the parts house this morning and they told me that I couldn't get a livewell timer module for my 93 stratos 217. Mine is the "circuit board" type and he tells me they quit making them over 10 years ago....anyone got any advice or suggestions on how to get it back working?
Silvertip
Re: 93 stratos livewell timer module
Sure! You can buy a live well timer switch right here on IBoats, Cabela's, Bass Pro or any local department or farm store that sells boating equipment. These are integrated units meaning you remove your existing switch and timer module and mount the new switch. There are only three wires. +12 volts, the line to the pump, and ground. One type has a fixed on-off cycle (30 seconds run, off for 3 minutes). A second type is adjustable. Both can be operated manually.
