'93 Merc 3.0l LX with 1.84 Gearing Prop Choices
thormx11
So I have a 1.84 gear ratio outdrive with my 3.0l merc engine. The boat is a 20' cuddy. I am getting about 4200 RPM at WOT, while running about 33-35 mph (according to the speedometer) The outdrive has a hydrofoil on it as well, and has no problem getting up on plane.
I have read that WOT should be around 4400-4800 for this engine. Do these numbers sound close to what they should be or should I try a different prop to make up for the different ratio? The boat cruised at about 28 mph or so while running 3700-3800 rpms.
It currently has a 14.5x19 prop on it right now.
drop down to a 17p
if you want more speed, loose the hydrofoil
thormx11
Thanks for the tips. How much does the diameter affect it? If I do decide to go with a different prop, should I stay with the same diameter and only change the pitch?
I am new when it comes to props (never had to change one on any of my previous boats)
alldodge
If your tach is correct and your normal cruise rpm is the 3700-3800, dropping to 17 will get your cruise in the 3900 to 4100 range. The motor will run easier but the peak torque may start falling off. Reason I bring this up, is current cruise rpm looks good, but running at the higher range for long periods needs to be thought thru. The 17 could be a good fit if its cupped to make it more of a 18 by reducing slip
Diameter makes a difference but so does everything else. Pitch makes more of a difference then diameter.
thormx11
So should I try to find a 14.5x17 prop? Or should I change the diameter as well?
Or, do I even need to change the prop at all? It seems to plane out very well, even when pulling a tube, and I am not really concerned with getting more speed, I just want the engine to operate at its optimal performance. I am happy with the prop set up I have now, I was just a little concerned with the low WOT rpm
alldodge
If you could try a 17 then sure, but since the boat is preforming the way you like, I would not be to much in a hurry to change. The thing that gives me concern is the high rpm where your cruise is. If it was lower then I would have no issue with going a smaller pitch, but being that high, might leave it were it is.
jimmbo
A 17 should put you around 4600 at WOT, and your 28mph cruise will require about 400 more rpm. If the tach is accurate, @4200 the engine is being overloaded, and that will sooner than later, hasten its demise
