When I turn the key nothing happens. I have to keep turning it and then sometimes the starter spins but doesn't pop up even with the key off. After awhile of continuously turning the key it will start. Sometimes when I shut it off the starter keeps spinning in the down position with the key off. Other times the motor doesn't shut off at all until I pull the emergency switch. I originally replaced the ignition switch hoping that was the problem but it couldn't be that easy. Any ideas of what causes this?
