93 johnson 9.9 Beeeeeeeping
88Will88
I was having trouble getting my 93 Johnson 9.9 to start. I thought that the starter was going bad so I replaced it. Doesn't look like that was the problem. Now I have a constant beeping noise that doesn't stop coming from the dash as soon as I turn the key to the run position.
pieman22
Re: 93 johnson 9.9 Beeeeeeeping
beeping alarm usually means oil problem. Check your VRO and make sure its pumpimg oil.
hidef
Check your temp switch circuit that is a heat alarm. Either the temp sensor has gone bad or it could also be a short in the system. The horn could also be acting up they have been known to fail from time to time also.
