93 Johnson 40 cranks and won't start
Seabass1020
I have a 1993 Johnson 40 model J40EETB, short shafts, 2 cylinder 2 stroke with VRO. It cranks and fires sporadically but won't start and run. I have no spark on either plug (unless my tester is bad). I replaced the plug and cranked the motor and the plugs smell like gas, so it's getting fuel (right?) I replaced the powerpack at the beginning of last summer after following step by step the procedures for troubleshooting from CDI electronics, that seemed to instantly solve the problem at the time. I dont have access to a peak volt meter, however so I couldnt test ever thing they said to. My motor had a real hard time restarting on the lake on my last trip and finally started but died and had to be pulled in. Since then it's been started and idled for aprox 20 seconds but nothing more. Checked compression and have 102 and 105. Never got any alarms. Not a mechanic but I read a lot and appreciate all the help in online forums, this is my first real post.
One more issue, maybe unrelated: the trip before the motor died, it was running very smokey, I think there was water in my fuel, so I changed the fuel and that seemed to solve the problem, but it was my test run when the motor died.
Also, do I need a water barrel or muffs just to crank the motor briefly? Like to do a compression test? If it runs without water for a few seconds will that damage the impeller or overheat the engine?
gm280
:welcome: Seabass1020 to iboat. Let's see if we can answer a few of your questions.
Any time you crank your engine, even for a few seconds, you need to have a supple of water so the impeller is not running dry. Since the impeller is made out of rubber, it doesn't take much friction to damage it running dry. Second thing, you can do a compression test without water because you don't have any plugs installed and there fore the engine can't crank up. Once you get the latest compression numbers, post them here for us to see. Then we can offer suggestion and ideas to try other things. I would also get a spark tester and see if you have a good spark. It should jump about a 7/16" gap with have a good blue color and nice snapping sound. Post your results.
Seabass1020
I used an inline spark plug tester (its a light thats connected to the sparkplug wire and the plug itself) and it showed no spark on either cylinder (unless I'm not understanding how this works). I did a compression test and found 102 psi on the top cylinder and 105 on the bottom (good, right?). In terms of the water pump, I might have messed up, as I have "cranked" the engine (turned it over with the starter motor) while testing the plugs and in an attempt to start it. I've changed an impeller before, so if that ends up being my only issue I'll take care of it. The online directions I found for the compression test was to screw the meter into a spark plug hole and turn the motor over... this is "cranking the motor," right? I want to make sure I'm not confusing my terms.
boobie
Go to cdielectronics.com for trouble shooting on the ignition system.
sargedog1
you can build a peak voltage meter adapter for your DVOM. Search Google for a schematic it's nothing but a resistor, capacitor, and diode of correct values soldered together. Purchase a project box 3" square some banana sockets and old test leads to connect to your current meter and poof. I've built several for friends and myself cost is about ten bucks in materials from Eliot electronics.
jakedaawg
Here would be my suggestions:
1. The fact that you do not have any spark with an inline tester is okay at this point, eventually you will want to get an open air gap spark tester as these tell you the strength of spark. But no spark is no spark.
2. Double check kill switch and lanyard are properly installed.
3. Remove plugs. Clean and tighten with a wrench the battery cables (make sure battery is good, many auto parts stores will load test it for free). Check spark again now that you have double checked the lanyard. I guess you will need one plug installed due to useing an inline light style tester.
4. If still no spark locate your power pack. Coming from the pack you will find a five pin amphenol connector. Un plug it. Carefully push out the pin that has the Black w/ yellow stripe wire. Plug connector back together. Do you now Have spark? Do not attempt to run engine if you find spark.
5. If so, ohm check key switch and kill switch assy. Procedure for this is in the sticky at the top of this forum I believe. If key switch and kill switch test okay then you have to check the Blk/yel wire for shorts to ground between the key switch and power pack. If all is good its usually safe to replace the pack.
6. If you still don't have spark after the first part of step five you will need to get some tools to further diagnose. An ohmmeter and an analog peak reading voltmeter will prove valuable.
All this is solvable, but you need to do these tests in order while paying attention to detail, responding to questions will allow you to get better answers from the many knowledgable techs that frequent the site.
The compression readings you list are questionable, a little low, but that could be the gauge. Compression will not affect the no spark condition.
The heavy smoking is most likely due to too much oil in the fuel, this could have happened if you had a fuel restriction or a fuel issue causing the VRO to over oil. Not a big deal yet as we need to get you spark first, then we can solve the rest of the issues.
Good luck! And Happy testing this Labor Day!
Seabass1020
I double checked my emergency kill lanyard, it's correct as far as I can tell. There's no other kill switch. I removed my battery from the battery box to eliminate any possibility of that posing a connection issue. The box kept the terminals looking new. I wire brushed the leads that connect to the motor. I'm waiting on the battery to charge, just to make sure, then I'll retest the plugs for spark.
In the mean time, I located the only 5 pin plug connected to the power pack. It appears to have 2 wires that are black with a yellow stripe. One of them already has a quick disconnect, from a diagnosis attempt I made 2 years ago. (It turned out to be the powerpack that time and a new one solved the problem. Motor has been run a lot since then)I don't know if this was the correct way to go about it, but I cut the wire to eliminate the kill switch as the problem. Needless to say I crimped this connection together VERY carefully and it's been wrapped in electrical tape since. Does disconnecting (and preventing it from grounding) accomplish the same thing as removing the pin from the plug as suggested by jakedaawg? If not, which of the two pins do I remove? I've already practiced removing and installing a pin from my old powerpack. Never knew plugs worked that way.
jakedaawg
There is only one blk/yel in that connector and your disconnect will prove sufficient. Usually it is the middle of the three pin row but wire placement changed from year to year.
jakedaawg
Iguess there could be two if you mean one blk/yel from each side of the connector.
I am away from any diagrams at the moment. Maybe one is blk/yel and one is blk/wht. Someone else should chime in here soon. Fed emdsapmgr flyingscott
