Mikebrown_23
Thread starter- Joined
- Jul 10, 2016
- 3
So here's what I've got: 1993 Johnson 115. It sat during the winter and I went to crank it. It would not crank. I changed the power pack due to no spark on any plug. After this it took a little bit of turning over but I got it to fire up. I had to keep the throttle up to keep it running tho so I idled it up some. Went to put it in the water and it was really hard to start. Finally got it started and I took off. I got it up on a plane and was cruising for about 1/4 mile then it bogged down. Couldn't get it to go. So I had my passenger prime the bulb and it started to go again. We did this until we got back to the dock. So I put new carb kits with floats in (I did find one needle valve with a piece of rubber jammed in it)and also replaced the fuel line and bulb from outboard to my in line filter. Cranked it on the hose and it fired up better than ever. I had to idle it back down. Finally got around to taking it back out today. I launched and fired it up and it idled a little low but did start right up. So I went to take off and it bogged again. I gave it throttle a few times and then finally got it to go. I figured it was air in the lines. I went about 4-5 miles and came back closer to where I launched and cut her off and did some fishing. When I got ready to go it was not wanting to start easily. I got it started after turning the key then pumping the bulb and doing this a couple times. Then I go to take off and it bogged again. I never could get it back up on a plane without it bogging and dying a few times so I just slowly came back to the dock. I got it home to flush it out and it fired right up and ran perfect. Any ideas of what's going on? I can't understand why I was able to go 4-5 miles only to have the problem come right back. Anybody have any problems like this?
