It started at WOT, a little burble and slight loss of top speed. I'd ease back on the throt a little and things were fine for awhile. Then I had to run about 3/4 to keep an odd hesitation out of it (seemed like fuel starve out). Then the random shut downs and gauge gremlins. Now it starts easily, seems to run good, SMOKES like a chimney and won't get on step.
replaced: plugs, fuel pump/filter/lines and ignition switch
cleaned: fuel pick-up, check valve, carbs/bowls, batt terms and connects
eng. ser. OEO30788
black stator
good comp. on all 3 cyl.
batt. 13.7 dcv
bright blue spark at all 3 plugs
no errant current jumping around coils
ohm meter at rx1000 scale readings:
disconnected red/blue wire
stator- red to blue = 1100
red to ground = 0
trigg- purple = 1100
white = 1100
brown = 1100
what to do next? local shop say's it can't be tested out of water and charges 65 bucks each time he needs to take it down to river for testing. dude's playing with a full deck a JOKERS!
eng. ser. OEO30788
black stator
batt. 13.7 dcv
red to ground = 0
white = 1100
brown = 1100
