moultriedawg
- Apr 16, 2009
- 5
I have a 1993 Evinrude ocean pro that runs great 90% of the time. every once in a while it will slow down all of a sudden. w/ out touching the throttle it will pick back up to full speed. had carbs. cleaned still same problem. had compression checked. all cylinders seem to have good compression. all cylinders has good spark, but when you pull the the wire from the plug on cylinder # 2 there is no drop in the engine. trigger and stator checks out. any help would be great.
Thanks,
Thanks,
