93 115 johnson mixing vs vro?
Tylernpalmer
I just bought a 93 sea nymph with a 115 johnson. I've been doing a lot of reading and it seems like it's a toss up between capping vro and premixing. I don't even know what year the motor is exactly. So the questions start. How do I figure out what year it is? Is there a way to test the alarm for oil flow? Or to test the low oil alarm? Is there any way to test the vro itself to see if it's working? Would there be any problems if I mixed gas in my built in fuel tank? Thanks in advance.
Vic.S
boobie
You can also get the info you want in an OMC Factory Service Manual.
batman99
I use Pre-mix 50:1 in my 1995 115 HP OMC and it works great. For simple conversion, I left the VRO factory fuel pump and blocked off its Oil tank flow side. Lots of U-Tube clips to perform this bi-pass. This year, I plan to remove its factory VRO pump and install old style mechanical pump. And, replace is old inline fuel filters and Fuel Seperator filter canister as well.
oldboat1
I would first check fuel quality if there was some in the permanent tank. Don't add gas before confirming what you have -- pump some out with the primer bulb, motor clip temporarily removed. Let it settle in a glass jar and look for impurities, particularly water (settles at the bottom of the jar -- and the tank).
Honorary Supreme Mariner
On a " new to you " crossflow outboard the first steps are a compression test to get a base line for the future.----And install a new waterpump impeller.
