Hi all, I'm back.
In 2004 I was here with this same outboard and with every ones gracious help was able to replace the power-head with a reman unit and solve the problem that caused the failure. It had overheated and scored middle cylinder.
In 2011 engine began to run badly & I saw a slight amount of oil coming from under the flywheel. Well, at the time I didn't want to deal with it and parked it. Now I've got the bug again. Checked the compression and have 100 psi on all three cylinders dry, so I don't think I've damaged the engine. I ordered an upper seal, carb kits fuel filter and a water pump kit to get her running again.
Upon removing the flywheel and timing mechanism I sprayed WD-40 around the seal and turned the engine over by hand to verify the leak. To my dismay, bubbles appear around the upper bearing race on the port side at the case seam. So it looks like I have a bigger project on my hands. I do have a couple of questions now and I am sure more will follow as I get into this.
My concerns are, Is 100 PSI an indication of a healthy block-piston? I did not try the test with oil in the cylinders and it is surely dry after not being run for 7 years.
Secondly would I be foolish to do this without removing the cylinder head and pistons? We have no local dealer and everything must be ordered in. I would prefer not to remove pistons but if I must I need to order more parts to do the job.
I plan on ordering the upper bearing o-ring(I already have the seal), lower head seal and o-ring and reed plate gasket and of course the appropriate Gel-Seal replacement to seal the crankcase.
Am I missing anything?
TIA, Roy
TIA, Roy
