azzeron81@gmail.com
- Jun 21, 2016
- 3
My 92 Suzuki Dt 100 will start on land but not with a load on it. Took the carbs apart and found a hole in the float. I replaced the float. And it seemed to run smoother but without any hp. I recently put carb kits in it. And took it out for a test drive. It would die out the second I would put it in gear. After tinkering with it for a while it came out of it and started running great. After about an hour of running it started to die an choke out again. I'm pretty sure I burned a spark plug out that I just replaced for the third time. Also seems it's not getting enough oil through the lines.
