VE175GLENC motor - bought 6 months ago - before that it runs and acts like the previous owner wasn't using it much, so I assume it had sat a while, couple trips a year kind of guy. Up until recently it has been hard to start and even after new batteries and starter, sometimes its just a futile effort. Once warm, it was just a bump of the key on the days it ran. This weekend it flat out would not start so I went exploring. Pulled the primer solenoid and lines. Solenoid clicks and pops up but the lines were old and clogged with ethanol, primer push would only drip fuel. So I replaced lines not solenoid. I did not check the voltage at the primer but with the new lines, fuel would stream out about 4 inches, not shoot out, of the primer when engaged but an improvement. Replaced, put back together, let it sit for a couple hours since battery needed a charge. Come back, (warm afternoon in the sun), bump key, fires up on the hose, never engaged primer. Next morning take to lake for test run, drop in and it just cranks and cranks and cranks, will not fire. Drained batter trying again.
Additional info:
New plugs and wires.
When attempting to start after a while its just puking fuel & oil through the exhaust. I look like the exxon valdez while trying to start this thing on the lake. Bring it back home, charge battery, come back in PM (warm out), bump key, fires no primer.
So now it feels like I'm in a spot where the damn thing will start on the hose but not in the water. Any ideas before I tear the carbs off and start a rebuild? Its starting to eerk me. Thanks for any help.
Additional info:
