92 procaft eletrical problem
cridley
I just purchased a 92 procraft with a 150 Mariner. I was removing a after market fish finder and I think I shorted shorted the ignition and trim. The fish finder power was coming from the ignition and I didn't unhook the battery when i remove it and sparks flew. I have power to everything in the dash but the trim will not work and the it will not turn over. Is there a fuse that i can replace to fix this. I noticed that there is an inline fuse coming from the battery, but i put the test light to either side and it seems to be letting power through. Just bought it and feeling a little over whelmed. Any one got answers?
Silvertip
Honorary Supreme Mariner
Re: 92 procaft eletrical problem
You blew the fuse under the engine cowl. These are sometimes difficult to locate but follow RED wires. Sometimes these are the short, round fuses that fit in what looks like nothing more than a rubber bump in a line. Sometimes blade type fuses are used which look like the fuses in your car.
cridley
Does this allow power to run back to the ignition switch, because there is no power reach the key.
cridley
Found it thank you so much for your quick reply and information. I will defiantly use this site again for information!
Silvertip
There are two electrical systems on a boat. The large battery cables connected to the engine feed the engine electrical system and yes -- the cable that runs from the engine to the helm carries power to the control box and the instruments. The two smaller gauge (usually #8 or #10) wires at the battery run forward to power the fuse or circuit breaker panel. This is the circuit that powers all of the accessories EXCEPT the gauges. Obviously if you bought a used boat you have no idea what "creative wiring" has gone on but what I just described is how the boat and engine were born.
