92 model Evinrude XP 200 question.
Sivart
I just bought a 91 Astro Fish N ski with a 92 200XP. THe question I have is the height of the motor on the transom. The top plate above the prop is setting about 3.5 to 4 inches above the bottom of the boat. On the test drive when the motor is trimmed it looks like the water out of the tell hole is slowing down quite a bit. The water picks up after the motor is trimmed back down. Does my motor need to be lowered? It is on the 2nd to the highest setting right now.<br />Thanks in advance.
rickdb1boat
Re: 92 model Evinrude XP 200 question.
Yes. The cavitation plate should be even or slightly above the bottom of the transom. I would be carefull with the water pressure running it that high. I'd drop it all the way down.<br /><br />
Sivart
Rick, I can tell that the motor used to be all the way down but before I bought it someone moved it up 3 inches. What would be the reason for going so high with the motor especially since the water inlets on the lower unit are basically even with the bottom of the boat.
rickdb1boat
Hard telling. Maybe they were using a surface prop and had a low water pick-up on it to make it perform better. Maybe they just didn't know any better. Nonetheless, it's gotta go down some. You may want to try a hole at a time until it fells right.
Sivart
RickD,<br />I lowered the motor this weekend and test ran. The water pressure seems to be a little better now that the motor is lowered to its lowest setting compared to before. I may have lost 2-3 mph but doesnt matter to me much. Thanks for your help.<br />This boat sat for about 6 to 8 months before I bought it and know there is some bad gas left in it. I have added about 15 gallons of fresh. When at idle for a while it seems to load up. You get into it to plane out and it bogs a little and then takes off. When you stay in it it runs fine and smooth but as soon as you slow down below 1500rpm it runs rough. I am thinking I may just need to put more run time on it???<br />1 more question. After starting it takes a few before the water pump kicks in. Is this normal? After the motor is gassed up to about 2500 rpm then water is really moving out the "tell" hole.
walleyehed
Service the water pump before you blow'er up.<br />should be shootin' water in less than 5 seconds...
Dhadley
I see a couple of things here. The water pressure should be monitored by a pressue gauge, not by the overboard indicator. That is only to tell you water is indeed going through the motor. The gauge will tell you how much.<br /><br />I believe your boat has a pad and a step (notched transom). If so, the motor can be run higher. Thats the purpose of the step. <br /><br />If you lowered the motor and the top speed fell off we can assume the top capeable rpm's fell off too. That may be a problem depending on how far they dropped. We dont want to lug that motor.<br /><br />Since the motor is lower, now is a good time to get a baseline on the water pressure for future reference. As Kenny suggested I would throw a new pump kit in right away.<br /><br />Gas thats 6 to 8 months old has probably lost some octane. Adding 15 gallons to it only means you have 15 more gallons of gas that needs to come out. Use fresh 87 octane only. Even adding 93 octane to what you have doesnt raise the octane level. It doesnt work that way unfortunately.<br /><br />Those looper blocks have quite a large water cavity so it may take some time before you see water out of the overboard indicator. Your pressure gauge reads pump pressure so it will start to register slightly before you see water out the indicator.<br /><br />Since the motor sat for an extended period and runs rough I would suggeat cleaning the carbs. A partially clogged jet can cause a lean condition. Pistons in a two stroke dont like that.<br /><br />Just an FYI (I'm sure you already know this) -- use Champion spark plugs only.<br /><br />Good luck!
Sivart
This does not have a water pressure gauge on it.<br />If a person was to put one in where would you hook it up on the motor and what pressure should it be?<br />After dropping the motor I got the rpm's to @ 5800 to 6000 rpm. I was around 62 mph.<br />I put new Champion plugs in it and gapped them to what you had recommended before .030. The boat runs great when you above about 2000rpms. Just above idle is when it cuts out and bogs. It takes a few seconds to catch up with itself and then runs great. I had hopes the plugs would clear it up. It does seem the more its ran the better it gets.
Sivart
I forgot to mention. The boat does have a step but only about a 4" step. Even after lowering the motor the cavitation plate is still about 2" above the bottom of the boat (the step).
Dhadley
Youre right on with the rpm's now. Very good!<br /><br />The water pressure gauge reads from a port in the adaptor housing. Its on the starboard side under the throttle linkage. There should be an allen headed plug in there now. Your kit will have specific instructions.<br /><br />Sounds like youve got her dialed in pretty well.
Sivart
Dhadley is there a certain pressure I should be looking for? What is good and what is bad?<br />Thanks for all the help.
Dhadley
At idle you'll probably see 3-4 lbs or so. It should climb rather quickly with the rpm level to over 20 lbs. minimum. My 200 topped out at about 30. It'll live at 18 but will cook at around 16 lbs on a sustained run.<br /><br />The best thing is to put in a new pump kit and make a note of the pressures at any given rpm. Also verify that your overheat alarm works. Your motor is equipped with SLOW so if it overheats it will automatically reduce the rpm's but lets not let it overheat to start with.<br /><br />Good luck!
