92 Mariner 100hp - Need help identifying part for fuel hose in the engine
c0rd23
I have a 1992 Mariner 100 hp. There's a fuel hose behind the port side of the engine cover that fell apart. I need help identifying the replacement parts needed to repair it.
The hose is the in the upper left of the yellow box in the attached image, in the bottom left is the brass looking part that the hose was attached to.
Thank you for your help.
oldman570
The web site at Crowley Marine has the diagram and part numbers you are looking for to fix the fuel pump system on your motor. Go there and look under the Mercury listing for parts. Then you can go to the parts for Marnier and find everything. JMO
Oldman570
