92 Johnson 60hp missing at higher rpm's
krakkaplz
I have a 92 Johnson 60 hp outboard and the motor runs ok at low rpms. At about 3/4 throttle it starts to miss. If i back the throttle off it runs ok agian. I have had the carbs cleaned and tuned, replaced fuel pump, new power unit, new lines, bulb and filter, new plugs. I have it on a 24' pontoon. Is there anything I am missing here. I cant seem to figure it out. It seemed to me it was starving for fuel but I have tried everything I know to do. Any help would be appreciated.
Honorary Supreme Mariner
Re: 92 Johnson 60hp missing at higher rpm's
Have you checked for overheat ?----------Have you checked the RPM that the motor is running at ?------------What prop pitch are you using ?
krakkaplz
It is not getting too hot it does it even if the motor is cold. I have no gauges hooked up to the motor so I dont know the exact rpms but I know it isnt running at max rpms. No clue on the prop pitch. Everything is still factory and is mounted on power trim. Came off of a bass tracker bass boat. Ran fine a couple years ago but started this the beginning of the season last year. I still ran it but began replacing things throughout the summer. I was told to it could be the timing is not advancing but not sure how to check it on this motor. I am ordering a manual on it this week.
ski332
Hey Krakkaplz have you found out what problem is with motor? I am having same problem with mine its a 1989 Johnson 60hp Would appreciate any info you have on problem.So far I have done a spark check a compression check and have had carbs rebuilt don't know what to try next
GA_Boater
If you start a new thread you might get some help. The OP made these two posts and left, not to return. Please read the Help Tips on top of the page.
