The warning horn is usually found as part of the control box parts list. The first question is, what type control box do you have in your boat? The first assumption is always that the manufacturer of the boat installs a control box from the same manufacturer as the engine. That's not always true anymore. Many boat companies will use a Teleflex control box with a Johnson engine. So-figure out who made the control box that's in your boat right now. If it is a real OMC control box, you can go to the OMC parts diagram website and look up your control box for your year engine. Check this out: epc.brp.com. When you get into the parts lists, make sure you navigate to the Parts and Accessories section, then look up your year-then go to the control box section. You should find a number of factory control boxes listed there. The warning horns are in different locations, depending on which box you have installed (flush mount, conventional side mount, or top (binnacle) mount....) If you have an aftermarket control box, you'll have to contact that manufacturer or contact the Grady-White folks for more information.
