92 Force 120
oodlesiggy
My carbs have quite a bit of fuel in them. I have just been taking the cover off and spraying some cleaner in them and it fires right up every time during the trip. If I do not do it before launching it struggles mightly to start, killed my battery one day trying to start it w/o spraying the carbs.
jerryjerry05
Re: 92 Force 120
Do a compression/spark test???
Then check the choke circut??
Comp low,post your results.
Frank Acampora
Re: 92 Force 120
Are you pushing in the key and holding it in while cold starting? Are you cold starting with the control handle in fast idle/warm-up position?
