92 evinrude 35hp vs 40hp Japan mariner
Falco198
Hey guys I have a 40hp Japan mariner lost the lower unit in a grounding accident bent prop shaft prop and other things gonna be costly to repair due to labour as I found the parts used bolts are seized everywhere bearing carrier included
My question is the guy offered to trade my motor for a 35hp evinrude I'm wondering what to expect in performance the 40hp mariner used to push me in my 16.5ft runabout 34 knots on the gps any thoughts on this and weight differencw
jakedaawg
Was there a 35 in '92? If so go with the 35 assuming it passes comp and spark and l.u. pressure test.
I read this as you get a running motor fir free
Falco198
Yes the motor will be serviced before I get it and it's just a straight swap I'm not 100% on the year he said it was close to my 40 which is a 92
Honorary Supreme Mariner
I would be checking the model # of this 1992 35 HP motor !!!
jakedaawg
Problem with that is if its an older 35 its rated at the crank.notnthe prop. Year is important
Falco198
Let's say it's based on the new hp models at the prop any thoughts on performance vs the 40
Falco198
The guy did say it was close to mine so what years were those motors made around that time
jakedaawg
Just have him give you the model #. Post it and we can answer. Guessing will not work.
