toddschubert
- Sep 3, 2011
- 504
88 spl trim problem. Most of the time when I press the trim up button I hear the relay click the motor does not come on or move up. I have to click it several times and finally it will move. When the engine is running and I am cruising in gear it seems to trim up and down just fine. It seems to happen only on the battery but my battery is fully charged and producing 12.6 V. I have also put a charger on the battery while pressing the trim button and it still does not help. Because I hear the relay click I would think it is a low-voltage problem especially that it works while running but I'm just not sure because the battery is producing enough voltage and amperage. The battery starts the motor just fine. The trim down motor works just fine always.
Any suggestions as to what this may be, a relay going bad perhaps?
Thanks
Thanks
