tpacracker
Thread starter- Joined
- Feb 16, 2003
- 2
ok, first...first time boat owner(other than a canoe)so I'm learning...and also, female. Bought a well-kept used pontoon with above mentioned motor...set for about 5 months prior to my purchasing...ran good from trailer...launched, and power not so good. Replaced sparkplugs and fuel filter(not personally), no help. Finally called in "expert" who advised, "good spark, comp 1-135, 2-10 3-135 lbs, #2 cyl bad, maybe piston & cyl problem. $2000 plus to fix". What is advisable? spend more $$ to rebuild? tradein on new outboard? What do you have after fixing an 11 yr old Evinrude? I've read some of the other topics...and there seems to be alot of older motors on the water...and by the way, money is a factor...any input is appreciated.
