Roughneck1860
Thread starter- Joined
- Mar 30, 2008
- 41
I just picked up a 92 50hp Merc. Its the 3 cylinder and has tiller steer. It seems to idle a little higher than it should. I'm going to say around 1000rpm or a little more. At idle it trolls a 4mph, it also goes into gear hard. I have the idle stop backed off but the carb's themselves were already bottoming out. Is there any other way of slowing down the idle? There dosnt seem to be an adjustment that stops the linkage on the carbs so I'm not sure where to go. There's an adjustment screw on the top/side of the carbs just behind a jet. Any suggestions?
Thanks
Tim
Thanks
Tim
