imported_Walleye1
Thread starter- Joined
- Mar 12, 2007
- 4
Recently started experiencing problem and would like to hear your ideas before I take boat/motor to mechanic.
Motor starts fine, water flowing out of tell tale in good steady stream at all speeds. Motor readlines at about 6000 RPM, I have never exceeded 3800. Equiped with a sensor which sounds a a continuous horn when overheat condition detected, automatically dropping RPM's to about 2500.
Recently in 3200 - 3400 RPM, after going about 500 yards overheat horn sounds, water coming out of tell tale fine. Immediately stop engine, sit maybe 5-10 seconds, engine starts right back up, and run again. At that point, I take it easy and run 2,000 - 3,000 RPM with no more overheat horn sounding and no problems.
This has happened the last 3 times I have taken the boat out.
Your ideas on what to check first appreciated. Was told by a non-mechanic that he experienced an overheat condition with a different motor due to a loose plug and timing being off. You will probably laugh at me but I haven't changed my plugs for two years because I haven't experienced any problems starting or running until now. Water pump/impeller changed within past 2 years and seems to be pumping fine. Thanks.
