92 120 looper tach
Jannise2011
I have a stratos 274 with a 92 120 looper that tach and charging quit working. To verify it was tge regulator/rectifier I jumped the gray wire to the yellow and yellow/gray wire. The tach started working. This told me for sure regulator was bad. I ordered one lastnight. But my real question is can I leave this jumped so I can run it this weekend have still have a tach? Or will it hurt something?
tlewis1
I would disconnect it. The stator puts out a AC charge while the rest of the boat runs off the DC that is converted by the rectifier.
Jannise2011
Isn't the solid yellow and the yellow with gray stripe the DC side of it?
If it wasn't, seems like it would fry the tach right away when I jumped it.
Faztbullet
Yellow wires are AC voltage in and rectifier/regulator convert to DC voltage for battery charging and accessories....it wont hurt to run tach this way as the tach signal is off the AC pulses.
Jannise2011
Aahhh I got ya. So just to be clear I can run it this way for the weekend and it won't hurt anything?
