Hi all - I had a new impellor, thermostats and water pump kit put in about 13 months ago. I suppose it might be time for a change, although not used more than 6 times since, because she is suddenly sending off the alarm above 5000 rpm when at that level for more than about 30 seconds. It seems to cut a few cylinders and after about 30 secs at idle I turn it off and back on and she is fine (provided I dont again exceed 5000 rpm). Is it worthwhile pulling the covers off and cleaning the galleys. Could it be that the diverters need replacing (never done to my knowledge). Could it be water pump. Or all three?. What is more probable and what would you do first - I was thinking water pump kit and impellor. Cheers.<br /><br />PS. I posted a while ago about stalling between moving from the forward gear to reverse and Rodbolt suggested cleaning the float bowls. I did that - full of crap - and it now runs like a dream at idle. Thanks Rodbolt.
