91 toon with 50HP Merc.
gpfishingdude
Could somebody tell me how big of a gas tank I need on a 18' pontoon boat? It has an old 50HP 2 stroke on it. So is there anybody out there with a 18 footer with a 50 HP motor that can tell me what size gas tank you have on yours and how long you can run it on a tank full. We just bought this old 18 footer and so I was wondering if I need a bigger tank. We plan on using it on some lakes that don't have marinas.
Treker57
Re: 91 toon with 50HP Merc.
I have the factory 26 gallon seems it could be over kill sometimes, but on long weekends or week vacation its great
mrbusdriver
I have a 18 ft. with a 40 hp on it that I use for fishing mostly with some cruising, I go out for half a day and use around 3 or 4 gallons a trip. I run it around 1/2 throttle maybe a little over that.
muskiemike12
Assuming you have tank tray's on the back of your tubes, two, 6 gallon tanks would suit you best.
MH Hawker
Run it awhile and see if its enough, and if it ain't add another 12 gal tank.
MinUph
We have an 18 footer with a 40 and a 12 gallon tank which is plenty. We go out for the day and burn about 3-4 gallons. Probably run at close to WOT for a couple hours and river cruise for another a half hour or so in and out.
Your engine will burn 5 gallons of fuel per hour at wide open throttle. Make your calculation based on that. Top speed will be 18 - 20 MPH so you can figure the amount of fuel you need to cover the distance you intend to travel. The rule of thumb is 1/3 of the fuel load going, 1/3 coming back, and 1/3 in reserve.
