91 Mercruiser 7.4l Bravo One Tripping Circuit Breaker
mstrianse
If fiel pump turns out to be bad, what do you recommend for a replacement? There are no markings on the current pump.
alldodge
Should have noticed sooner, or maybe I'm loosing it (forget that I am loosing it) but a 1991 454 uses only a mechanical fuel pump, so there should be no electrical connection
mstrianse
You are correct about a 1991 454 using a mechanical fuel pump. This boat had a new engine put in it before I purchased it and has a electric fuel pump and there is no plate for where mechanical pump would go . Would like your suggestion for replacement electric fuel pump. Thank you
