adirondakjack
- Aug 26, 2001
- 1
How can one check the powerpack, or sensors, etc on this critter? I have no spark, and checking voltage at the coil (little wires, I can never remember which is primary or secondary) I get only about .1 volts while it is cranking. What kind of voltages should be seen on the input wires to the powerpack? Trying to figure out whether to buy parts, or trust the only nearby dealer, (one who sold us a water pump, when a wasp had plugged the indicator line) so, I haven't too many choices if I can't figure it out. Is there a sender under the flywheel, like cars use to take place of points? I have been there and back with Ford cars, when it is impossible to tell if it is the hall effect switch, or module, until you change the wrong one, LOL! Summer is darn short up north, so any help would be greatly appreciated.
