91 force 90 HP trim & tilt Problem model 908E91H
Bryan Lupe
Tilt will left up 4 to 5 in and will not hold. If you release switch engine falls. Motor appears ok as it is pumping however will not work as designed.Four mounting screws were replaced as one of the four were broken off. The o ring was replaced no luck. I don't believe there is a presure check value on this model. Is rebilled the answer or seal kits, any advise would be greatly appreciated
