91 Force 150 Trophy boat
Bradforce
I have a 1991 Force 150 on a 21 foot trophy. Can someone tell me what is the proper way to use the battery swith?? 1, 2, or both for starting and running. Can I start on both then swith to 1 or 2???? Thanks Brad
Bradforce
Battery swith use 1991 Force 150 How do I use the swith properly
I have a 1991 Force 150 on a 21 foot trophy. Can someone tell me what is the proper way to use the battery switch?? 1, 2, or both for starting and running. Can I start on both then swith to 1 or 2???? Thanks Brad
RRitt
Re: 91 Force 150 Trophy boat
unless your switch is make-before-break then you shouldn't switch with the motor running. Everytime you do so then you run a small risk of damaging ignition electronics.
