91 evinrude 25hp won't stay running
jrob34
I bout a 91 bass tracker with a 25hp evinrude. It has been sitting for 1 year. About 2 weeks ago I tested the motor out of the water using a trash can. It ran completely fine after about 5 cranks. Ran it for 10 or 15 minutes with opening the throttle too. Put about a gallon of new fuel in it before I ran it. Came back 1 week later to take it out on the lake and it wouldn't stay running. After about 5 cranks or so it turned over and wanted to start, and probably on the 6th or 7th it turned over. It ran for maybe 3 minutes before dying on me. So I continued to try to start it. I gave it a fee minutes and tried it again. It tried to crank over but wouldn't run longer than 5 or 10 seconds. Any suggestions?
OBJ
Sounds like it's not getting the fuel to good. Are you squeezing the primer bulb till firm before starting? If you keep squeezing the primer bulb while it's running, will it stay running? If the primer bulb will not firm up when squeezing then one of the "one way valves" in the bulb have come apart and fuel is not staying in the fuel line to the motor. If you have not tried squeezing the bulb when the motor is running, try it. If the motor continues to run when squeezing the bulb then you may have a problem in the fuel pump. Or....the carb could be gummed up from setting so long and your running the motor on priming fuel. Take a look at the above and see what you find.
jrob34
I did pump the primer bulb before trying to start it. I did not try to pump it while it was running. Thanks for the info! Any is appreciated
