Looking at this thing in the daylight,I think my initial thoughts of bracket pin play are not the issue.
Just lifting the tiller handle up 3" from all way down,then down,up,I see the motor moving in relation to the base on the boat.
right where the tension bolt that adjusts friction on steering,hidden in housing.Must be rubber upper bushing here.
The motor has movement because dropping tiller handle is stretching the throttle cable,and the kill switch wire.
This is with motor not running,on my trailer.
It appears might need to replace both upper&lower rubber bushings,that upper looks to be a bear to get to?
Thanks for any thoughts on this!!
