I am new to the forum and have a 91 capri 21 footer. After pulling up the carpet, I discovered the "very thin" layer of resin they originally applied to the main floor is cracked and the top layer of the plywood in a few areas is peeing away. There are several holes that they used to pour in the foam visible and after peeling away the fiberglass and/or resin from above the holes, the foam is dry in 5 that I have checked. I DO NOT WANT TO PULL UP ALL THE FLOORING, BUT I WANT TO BE SAFE ALSO.
If I drill two 3 inch holes (with a hole saw) in the rear, just in front of the engine cover; one on the outer side of the two main stringers ( on the outside so I don't accidentally hit the gas tank) and above the foam, AND if the foam is dry in each, can I just redo the surface of the floor?
Although the top layer of the wood flooring is bad in some areas, there are no areas where I see soft/rot and I can not push a srewdriver into the wood at all..in any of the areas.
All the fiberglass coating in the engine compartment, beneath the two rear seats and everywhere except the main floor between the engine and front seats looks like brand new. Even in the main floor, 6-8 inches around the "edges" are like new.
