RyanInFlorida
- Jul 20, 2008
- 23
I have a 91' evinrude 88SPL . The last two times I was out on the water I noticed that after running for about 10-15 minutes, anything past 3500 RPM the water stops squirting from the tell tale. If I slow back down to idle it starts squirting water again. I usually let it idle for about 5 minutes and then I will power back up to 3500-4000 RPM and then 10 minutes later it stops squirting again. Is this the impeller that is causing this or poppet valves?
I just had the water pump impeller replaced by a local boat shop so I'm assuming that it should be ok?
I decided to pull off the thermostat cover and I noticed that there are no thermostats, but they are using a washer with a small hole in the middle. I've heard in Florida that you can run without the thermostats and use the washer instead? Is this ok or should I put thermostats back in?
I decided to take a couple pictures to see if any of the items might be bad. They all look good to me except one of the springs was shorter then the other...maybe that was the problem with the water not coming out (It broke when I tried to pull it to the length of the other spring)?
I also started the boat with the thermostat cover off and water was coming out from both sides evenly, doesn't look like a blockage.
Is there anything else I should be looking for?
I'm new to working on outboards so I could use all the help I can get
