reliablesources
Thread starter- Joined
- Dec 6, 2009
- 5
Hello Guys. New to this forum but know how it works.
If there is an answer to my question already on the forum, you can link it to me to keep from repeating ourselves.
Just bought a 91 Evinrude 60hp for a project. All is good except it spits at idle and mid throttle. Carbs are clean. Found Low speed screws as follows:
Top carb 1.25 out
Middle carb 1 out
Bottom carb .75 out
If i give it a manual choke it lines out just for a second. Seems like its not getting enough fuel. Do these screw setting sound odd to you. Factory service manual says to start at 2.25 out then adjust (assuming for all three carbs). And why would someone lean the carbs as they go down. if the settings are correct, why?? What should the settings be if they are not correct?
I know the duel cylinder, duel carb jetski setups but not sure about the vertical tripple outboards.
Thanks for the info
Tony
Top carb 1.25 out
Middle carb 1 out
Bottom carb .75 out
Thanks for the info
Tony
