rjrobin2002
Thread starter- Joined
- Feb 27, 2010
- 89
I just rebuilt the cylinder and did the lower and raise, refill process about 15 times to remove the air. It was working on my vise when cycling the cylinder up and down using a battery pack. I installed it and now it will not raise the motor without me assisting it while holding the trim switch up. The switch and motor is working and it will hold the motor trimed up after I get it up, so that should rull out the cylinder leaking. Any advice. It will lower the motor fine after I assist it up.
It was working fine before the rebuild/reseal, it had just developed a leak at the top of the cylinder. Do you think that when I was running the trim motor before the rebuild low on fluid could of messed the pump up?
