Captain Stagger
Thread starter- Joined
- May 27, 2008
- 2
Please excuse my lack of technical knowlage, kind of new to this so you will have to bare with me a bit. I picked up a 91 force for a 15' trihull......I have gotton the engine almost working. Inside the carburator i see two flaps......one on the outer edge and one on the inside. I am assuming the outer flap is for air control, and the inner flap for fuel control. When i turn the key the engine tries to crank, just wont get there. However if i push on the lever atttached to the inner "throttle flap" giving the engine more fuel it will start right up and hum just fine as long as i press the throttle flap lever. With out this flap opened the engine wont start. Now the solution?.....There is only one part that can move the throttle flap lever which is conected to the hand held throttle shift knob at my steering wheel. How do i adjust the throttle flap lever to allow the fuel to reach the engine with out having to take the cover off and do it manuelly?
Thanks for your help
