91 115 merc top piston
Coxy
I have a 91 115hp merc. I chipped pieces off the #1 piston head.
Bought Seloc manual to help fix but find it is very sketchy.
Can I remove the carbs and crankcase as a hole unit?
Also I believe I need to remove the flywheel at the same time?
If so looking for flywheel puller set,piston set, and so on.
I'm in Canada.
THX
latin monkey
Re: 91 115 merc top piston
how are your mechanical abilities? you're looking at a fair amount of work. you can buy a lifting eye and puller at any marine dealer or on ebay. yes you can pull the powerhead off with the carbs on. your best bet is to buy a factory mercury service manual for your motor and read up on everything that will have to be done to change out a piston
