90hp yamaha
army guy 116
got a 98 model xpress with a 98 model 90hp yahama on it boat has sat up since last summer motor cranks and idles great give it the throttle and it dies check all 3 cylinder for spark #2 is dead tried new plug and coil still dead thinkin a sensor has that cylinder shut down Any help or ideas would be greatly appreciated:
99yam40
Re: 90hp yamaha
A Yamaha service manual will help you troubleshoot the motor and perform the maintenance need on your motor. you can pick one up at your local Yamaha shop or online.
to help us help you you need to read and follow this. It will keep us from having to ask a lot of questions. hopefully it will keep us from guessing as to what your motor Model # is and what all you have done to it. Explain how you tested etc.
http://forums.iboats.com/showthread.php?t=250876
My initial thought is fuel issues if it idles fine, but I do not think it would idle fine on only 2 cylinders. What spark test did you do. I think that the 90s have 2 pulsar coils, 1 for cylinders 1&3 and the other for cylinder 2
scisgr8
Re: 90hp yamaha
This happened to me this time last year. I pulled the carbs out and cleaned them and then put them back in. there is also a float in each carb and sometimes they get stuck, just wiggle the floats good to make sure they move freely. I am incompetent when it comes to fixing things and I followed advice on this forum and it solved my problem with the exact same motor, so I would do a search on cleaning carbs for yamaha.
Good luck!
