90hp with vro
papasage
cant find a tag with ser# or modle # it has a # stamped on top between heads # are186691 & 22fn1 & 6-12-88-will this help in finding the year of this motor thanks papasage
OBJ
Re: 90hp with vro
Papa...what kind of a tag is it? Did ya' look on the transom brackets for a metal plate or a core plug on the block somewhere?
papasage
Re: 90hp with vro
tthere is no tag on it the plug # is r8157576 . the other # i posted is stamped in the motor on a flat seface between the head on top. papasage
OBJ
Re: 90hp with vro
Hi papa....<br /><br />Don't know for sure but the number you posted may be the cating date of the block which would make it and 88' or 89'. How 'bout the title for the engine. Anything on there?<br /><br />Jim
papasage
Re: 90hp with vro
outbord engins dont have to be titled in georgia . just a billof sales.
Dhadley
Re: 90hp with vro
It could be that someone rebuilt the motor and stamped a date on it. Kinda common around here.<br /><br />We're assuming that its a cross flow. The ehaust plated between the heads bolt to the block, correct?<br /><br />Most of those V4 cross flows were very similar so guessing at the age may be tough. Since it has a "VRO" emblem we can assume its not real old. <br /><br />Are you trying to buy parts or ..........?
papasage
Re: 90hp with vro
we cleaned the carbs but still want run wot.have a climers manul that covers the type carb . we are going to change the filter and re check the carbs .compression is 120on all cylinders and firing good all plugs wer wet but one on the bottom left . will work on it thisweakin thanks for thereply this board has ben a lot of help as i have 7 boats &motors . papasage
papasage
Re: 90hp with vro
yes this motor came from fla. wes palm beeach aera
papasage
Re: 90hp with vro
ran the 90 yesterday had to chock to git it to run at high speed it backfired 2 times thin ran good . guess it blue something out of the carbs .<br />papasage
