photoguy66
Thread starter- Joined
- Apr 30, 2005
- 13
I have a 1984 90hp merc inline 6, and am having some problems with it. I winterized it, took it out for the first time this year and it ran great, the second time I took it out, it started and idled fine, got it on plane at about 2000 rpm's (17ft aquasport cc)then the motor started bogging down and "pulsing",meaning revving normally then bogging down repeatedly, then I backed off the rpms and it would still run rough.brought it back to dock, idled it, noticed alot of dirty looking stuff coming out of the exhaust, figured it was stale gas, hooked up 5 gallon tank with fresh fuel/oil mix, no change.took out plugs which are brand new, all were very clean except #3 and #5 which were slightly dirty. Found one cracked fuel line which I replaced,took off float covers, cleaned bowls, sprayed with cleaner, started it back up, idled great, took it out 2000 rpm's, same scenario happened again, ran rough with lots of pulsing but idled fine and at low speeds, it ran fine and I got it up on plane but it only lasted for a bout a minute before the bogging and the pulsing started again.If there are cracks in the fuel lines would this be indicative of the problem? or does it sound more like a carburator problem,or maybe something else?Thanks Rick
