I have 90Hp Johnson with a mis on the top Starboard side cylinder. When I pull the plug wire when its running it does not change the way it runs, this is how I know it is the cylinder doing it. It has 120psi compression and seems to have good spark. I have swapped the coil for one that I know works and it makes no difference. can the carb cause only one cylinder to mis? it seems like it is getting fuel.
