90HP johnson 2004
bunno
I have a 90hp johnson which needs a piston replaced, i took it to my mechanic and he has broken the powerhead while trying to remove it, I was wondering if you needed to remove the lower unit first before the powerhead as he did not believe this was necessary.
Thankyou for your time
Faztbullet
What did he break??? No the lower unit does not need to be removed just shift rod disconnected. I don't think I would trust him to rebuild if he did something really dumb.....
Honorary Supreme Mariner
I believe there are a couple of bolts horizontally into that block.----Working on his first one was he ??
