90hp force wont stay running when motor trimmed all the way up??
thundercraft84
I have a 90hp force that dies when i trim the motor up it runs for about 30 seconds or so with motor trimmed up then dies there is gas dripping from carbs when motor is trimmed up.... any ideas thanks
mbhoag
Re: 90hp force wont stay running when motor trimmed all the way up??
I am definately not an expert, I am actually a newbie.... but here is my 2 cents worth..
I have an 86 Force 125 - If I trimmed it up high enough that gas dripped out of the carbs I can image two things would happen,
1 - Gravity would starve the engine and it would stall
2 - My engine would be completely out of the water
I cannot imagine either of our engines running very long or well under these conditions, but stalling when at this angle seems completely normal to me. Just my $.02 worth and may be completely wrong... I look forward to hearing from the experts!:confused:
mla2ofus
If you mean trimmed high enough to lift the prop out of the water, you're fortunate it dies. Otherwise you'd cook the engine from lack of water. I'm beginning to sense a troll anyway.
Mike
thundercraft84
My power TRIM IS F$#KED RIGHT NOW SO HAVE BEEN MANUALLY TRIMMING MOTOR BUT ONLY SETTING I AM ABLE TO PUT IT ON PUTS PROP JUST UNDER WATER WHATS WEIRD IS IT WAS RUNNING LIKE THAT THE FIRST COUPLE TIMES LIKE THAT NOW NOT SO MUCH..... IM PERPLEXED
Jiggz
Are we talking Trim or Tilt? Trim controls will not lift prop out of water, Tilt will. Trim is to control the bow when planing, tilt is to lift the prop out of the water when recovering especially in shallow waters and when trailering. And yes, when you tilt all the way up, fuel mix will puke out of the carbs. Which means to say if the engine is running, it'll die due to lack of fuel.
thundercraft84
sorry yea were talking about tilt
jerryjerry05
Sounds like your pinching a line some where.Or the inline connector is leaking at that angle.
Any old inline connectors can leak and suck air.J
milehighboater
I have a 75hp 1999 force made by merc and the manual says there is a safety that when the motor is tilted out of the water the motor automaticly shuts down to prevent damage. I have never attempted to start the motor with the motor tilted up though. I will say as soon as my prop is under it will run.
