90hp and 115hp power head interchange
mcb1one
Hello I was wondering if a 1979 115 complete powerhead, with electronics and carbs, etc.. would bolt to a 1985 90hp body? The lower units will swap.
I have a 1985 90hp v4 Johnson with bad piston (trim tilt) and a 1979 115 complete engine with no reverse (and NO trim tilt).
Would be best if I can just swap the power heads complete with all accessories, components from the good 115 onto the other assembly..
Would this work? Thanks for all insights that will help.
Chinewalker
I believe it would work as the base gaskets are the same from 1977 to end of crossflow V4 production in 1995.
emdsapmgr
You might want to just swap the powerheads and use all the 79 components. (electrics, carbs, etc.) Likely the 79 engine has higher compression heads than the 85.
mcb1one
Thank you. I will definitely give this a try. This way I can end up with a good 115hp motor with power tilt which it never had originally.
Thanks again
