90etlf oil pump
xltjon
I just bought a pontoon thats got 1989 90hp yamaha on it. The oil pump, tank and all lines have been removed. Should I leave it that way and pre mix, or look into replacing the oil system?
Mc Tool
Personally Id leave it ....mixing aint that big a hassle . Im thinkin that getting the whole kit ....even used wont be cheap .
I figure the 50:1 mix ratio by "double it and add a zero " ( only works for litres )
10L doubled is 20 ,add a zero is 200 , use 200mls oil for 10L fuel
xltjon
boscoe99
It is a cryin shame that someone with no idea what they were doing removed the oiling system. Very very reliable. Less mess. Less chance for an oil related failure.
Given the age of the motor, the availability of the needed parts, and the cost thereof if you can find them, I would leave the system as is.
99yam40
and hope they removed the pump parts properly.
