Black/yellow stripped wire to power pack is connected to ground by ignition switch to turn off motor. Somewhere the circuit is broken. Does pulling the safety switch lanyard shut off the motor? If so, problem is in the ignition switch. Otherwise, need to check the black/yellow wire is grounded when ignition switch is off. Single pin connector at the power pack for the black/yellow wire may also be the problem.
