90 johnson 60hp starting trouble!!
neffy
Ok boats been sitting for like a month. Worked fine last time I used it. Went to fire it up yesterday on the clam ears and battery cables started smoking and starter barely turned. So went and got a new solenoid today starter tried on first attempt to start engine but stopped. And now the starter wont turn at all. Only like .2 to .5 volt going to starter when trying to start good voltage on battery side of solenoid. Ground for starter??? Or is the starter trash?? Battery terminals on the battery melted down too. Not using that battery anymore. Using a good one. Any help is appreciated!
Bosunsmate
try jumping straight to the starter.
Also clean up your ground bolts. I wouldnt be surprised if all your cables have fried internally since it hot hot enough to melt those battery terminals.
Also check you can spin the flywheel manually (it aint binding)
neffy
Yea you can spin the engine manually. Yea gonna jump the starter when I get back home. Ill update when I do. Thanks!
neffy
Ok jumped right at the starter and starter works fine. So I guess wires or ground? I grounded the jump box right to the block ground and worked fine.
