'90 Johnson 60 VRO
RI0T
GreetingZ,<br /><br />I have a '90 Johnson 60 VRO that just won't start until I've just about drained my battery. Oil injection was disconnected by previous owner. Once started however, the thing runs like an elk up a mountain. And starts effortlessly. Only after sitting a while, becomes hard to start. My question: Does the VRO have something to do with this? Or am I not doing something right? IS there a starting procedure I've missed. I friggin wish it had a choke, than at least I could wiggle that for an hour or two. Does the VRO pump the fuel and does it need to be primed? Do I have some sort of vacuum leak? Geezus if I don't get this thing fixed, I'm gonna need a place to stay cauz my wife will fry my arse.
D
DJ
Guest
Re: '90 Johnson 60 VRO
riot,<br /><br />Use this procedure.<br /><br />1. Hook up fuel hose and prime until bulb is firm.<br /><br />2. Turn key to "on" NOT start.<br /><br />3. Push the key IN and count to eight.<br /><br />4. Release key.<br /><br />5. Turn key to crank (start).
