Denny of Pa
Thread starter- Joined
- Feb 25, 2010
- 10
Greetings,
Wonder if someone could suggest some "simple" possible answers, to a power problem. My 90 HP Mercury 2003, seems to start easy and seems to run fairly smooth , however it just will not power up to full power. It use to run my boat at about 40 MPH, but the most it will now go is about 30 mph. Could it be that it is only firing on 2 of the 3 cylinders. ? or would it run rough if that were the case ? but if that is possibly the case ,,, how can I check to see which cylinder in is not firing on ?
I would rather not take it to a marina if it could be as simple of a problem as changing a spark plug,, but since I am not that great of a mechanic, I am not certain how to diagnose the possible problem.
I would greatly appreciate any advise
Thank you
Denny
Thank you
Denny
